Edit Appended Printer info in generated Gcode file?
ArtKaiso
Posted (edited) · Edit Appended Printer info in generated Gcode file?
Hopefully someone can help me with this. When I import my .stl files into Cura 3.6,  it generates the Gcode file but appends printer info text. e.g. My file is "Bearing_holder.stl". Cura generates Gcode file called "CFFFP_BEARING_HOLDER.gcode". I expect the CFFFP comes from Cura's printer label type of "Custom FFF Printer". Some of my file names are quite long and I'd like those 5 characters back. Can this be done?
Edited by ArtKaiso
    Posted · Edit Appended Printer info in generated Gcode file?
    de nada!
