Cura wont open on surface pro
Crealator
Posted · Cura wont open on surface pro
I have installed Cura on my surface pro using the windows download but after it has downloaded, it does not open. It does not create an icon on my desktop and when I find and try to open it in my start menu, the blue circle appears for 3 seconds and then nothing happens. I have tried restarting my computer and reinstalling Cura. Any solutions?
    • 3 months later...
    • 1 month later...
    Right click the properties, under the Compatibility tab click the Change High DPI settings, at the bottom check High scaling DPI override, then under the Scaling performed by: [dropdown] select System (Enhanced).
    This worked for me running Windows 10 on a Surface Pro 4.  Fresh install of Cura 4.1.0
    Regards,
    J
