Thanks for finding that - yes I did have avoid printed parts when travelling checked. I have cleared it now.
Searching through the file now for "Y-" it finds a number of other cases (but no X-).
So the safest thing is to do a (automated) search through my gcode files for moves outside the print area to avoid this error happening again in the future.
I was just surprised that Cura was happy to produce this error.
Thanks again
Bruce
gr5 1,967
About 1/4 of the way into your gcode file I find this:
That's probably the offending line. It's at layer z=14.91. Y should never go negative. It's among a set of non-printing moves.
Do you have "avoid printed parts when travelling" checked? It's probably that. Try unchecking that.
I found the problem by removing all the X and Y from the gcode file and then reading it into a spreadsheet and asking for the min() and max() of each column.
gr5 1,967
Check this out:
https://ultimaker.com/en/resources/44677-maximum-build-volume-ultimaker-2-plus-ultimaker-3
