@joestefano, are you by chance using my SidebarGui plugin? That is not recommended with master (or when running from source, really). If you do, you will have to keep the SidebarGui plugin updated with the plugin repository yourself:
https://github.com/fieldofview/cura-sidebarguiplugin
The sidebarguiplugin "patches" certain areas of the cura gui. When there are structural changes to the gui, the plugin must be amended to patch the right parts. The currently "released" version (from the forum topic about the plugin) is compatible with Cura 4 beta 1 only. Once Cura 4 beta 2 is released, there will be an initial release of the plugin to the Marketplace (but this version will not work properly in beta 1). There may be another release when the final version of Cura 4 is launched.
nallath 1,118
They were moved as part of the redesign of 4.0, but other than that, they are still there.
