Thank you, Brulty. I appreciate your points on that. I have found that this issue of oozing can be easily addressed as follows. At extruder switch, active extruder is retracted 100 mm by setting position to -100. Then tool is switched to next extruder and instead of setting position back to 0 (thus reversing the complete 100mm retraction), the position can be set to -5 so that there is no oozing. Then the risk is only of missing a small bit of material on the infill, which I do not forsee to be a problem. The machine already retracts and de-retracts many times during a print. An extruder switch would be no different. Of course, this would not be universally applicable to every conceivable print, but gosh would it save a lot of waste material from the environment and save a lot of headache with failed prints. In my case, the print has a wide base, so it is not nearly as susceptible to knocking over as the prime tower. Another benefit would be that build space would not be taken up by the prime tower.
Brulti 176
That's interesting but you run the risk of the part being knocked over when the priming is done on the inside and the printhead is wiped against the inner walls. Or to have small bits of filament sticking out of your part and messing up the layers and the coloring, in case the priming isn't perfect and tehre's still some leakage.
It's been suggested to UM to make the prime tower conical: wider at the base and thinner at the top, to give it even more stability with the round shape, I do not know if this is on their todolist and would be implemented in Cura 4.0 or later, or maybe it is on list of things that would be nice to code but are not considered that important.
