The minimum value for the Z-Offset is the negative of the Initial Layer Height. If the Initial Layer Height is 0.3mm, you should be able to enter -0.3 as the Z Offset.
Specifying a value lower than (- Initial Layer Height) would result in a negative Z value in the gcode. The firmware would - at best - ignore the negative value, or give you an error. The firmware assumes that Z=0 means that the nozzle touches the buildplate. A negative Z would mean that the nozzle is below the top surface of the buildplate (ie: the nozzle pushes through the buildplate). Needless to say, the nozzle actually pushing through the buildplate would be "less than desirable".
PS: fieldOfView is known as @ahoeben on this forum.
1
Zenmaniac 0
Never mind. I found an adjustable mount for the BL-Touch so I can lower it enough that my Z-offset becomes zero for PLA and a positive number for PETG.
Sorry to bother.
