The profile I am trying to import is from Airwolf, but it does have dual extrusion support. although it looks like it might call for some other gcode? I am not too sure. I attached two of the profiles if that will help.
- 3 months later...
I am also having this problem. I am using the Axiom Dual and I would like to be able to import the profiles into Cura to be able to slice from the command line. Or at least be able to use Octoprint to slice for me. I try to import the ini file from Apex into Cura and it tells me that multi extrusion is not supported. The Axiom Dual is a dual hot-end machine.
nallath 1,101
You're trying to import a single extrusion profile to a multi extrusion machine. The old Cura didn't have multi extrusion, so there just isn't a way to do the conversion (or well, there is, but it's way too complex to put all of that in code).
