@Smithy thanks for the tips. I am currently having issues where The PVA is under extruded and I have to 'mock' changing material mid print to ensure the nozzle is not clogged during printing (i.e. unload and load again).
I notice that the material is grinded a bit at the extruder when it's under extruded. Is it because the nozzle is clogged or is it because of the extruder? The nozzle doesn't seems to e clogged though. When I reload the material mid print the material comes out of the nozzle fine.
Smithy 1,111
I use the Polybox which can feed from the top (if you put the box on the floor) or feed from the side near the bottom, which works great if you put the box on the table.
But you can also use any other solution or use a normal airtight container, drill a little hole for the filament and out some silica gel packs inside. It doesn't matter which box, everything works, just keep it dry all the time.
