CuraEngine.exe has stopped working
nick-foley
Posted · CuraEngine.exe has stopped working
I get this error all of the time when I try to slice high-poly models (50mb+) at a thin layer height (0.1 or lower)
It didn't happen before the SteamEngine upgrade. Anybody figure out how to get rid of this problem?
    Well - not what you asked - but you could reduce the polygons by a factor of 2X or 100X potentially without any reduction in resolution (resolution after printed). I love using meshlab:
    Click on menu item: "filters" "remeshing..." "quadratic edge collapse decimation". I set quality to 1 as recommended in a shapeways article about this subject.
    I had a model of a human with over 10 million polygons but I wanted to print it only .5 inches high. I reduced the polygon count to 10K polygons and it was still more than I needed. After reduction Cura handled it nicely (before reduction Cura had issues).
    (Back after 2 weeks vacation)
    Most likely it's a memory related issue, the released version abuses memory a bit. Can you see if the version from the new support material test also gives you this problem with the same models&settings?
        • 6 replies
