Can't pick the right support material
Sk7500
Posted · Can't pick the right support material
I have a new S5. According to the compatibility page I should be able to print Nylon using a PVA support? But when I choose that combination it refuses to slice. And when I installed the .04 heads in the machine it said the .04 print heads did not support Breakaway material. To get around the problem I told Cura I wanted to use breakaway material so it would slice and just ignored the fact that I have PVA in the machine. The print temperatures and speeds are similar, So I think I'll be OK but I'm missing something in the Compatibility chart. I figured using the "Recommended" Option would set all the parameters to allow use of Compatible materials. I was wrong.
Thanks
        • 4 replies
