tinkergnome 846
...in addition: Ultimaker printers do not use bowden tubes with metric dimensions (AFAIK).
You probably want one with 1/4 inch outside and 1/8 inch inside diameter.
Where are you located? Here's another example in USA: https://www.captubes.com/
Smithy 791
I am not sure, but I think I have seen Bowden tubes at the Bondtech shop where you can order per cm or so.
