Cura 3.6 Slicing Bug
nobio8
Posted · Cura 3.6 Slicing Bug
I prewied your GCODE in Repetier and it looks OK
Then I used the same Cura 3.6 profile in Cura 2.5.1
and at firs glance Model is sliced correctly, so there must
be something going on with 3.6
    If you want to try my release, you can find them here...
    https://www.dropbox.com/sh/s43vqzmi4d2bqe2/AAADdYdSu9iwcKa0Knqgurm4a?dl=0
    Oddly, when I sliced his original file in 3.6, this is what I got. I co not see the weird errors shown above. Or, it is just too early in the morning and I cannot breathe.....😜
    Posted (edited) · Cura 3.6 Slicing Bug
    smartavionics I sliced it again with your version of Cura
    and both Previews, Cura an Repetier's are the same no slicing
    error.
    I also imported my original GCODE (attached to my post)
    back to Cura 3.6 and preview shows errors correctlly.
    To summarise :
    1. 3.6 sliced my model with errors which are not visible in Cura preview
    when slicing
    2. If we preview GCODE in other slicers error is visible in all of them
    3. If we import the same GCODE back to Cura 3.6, preview shows errors
    as all other slicers
    We have two problems:
    1. Slicing with Cura has major errors
    2. We can not relay on Cura to preview the code correctly
    unless we import the G Code back again
    Edited by nobio8
    Have you tried the 4.0 beta? Perhaps the problem has been fixed since 3.6?
    I am curious to the fact that I am not seeing these issues on my 3.6 installation.
    Here is the G-Code.
    CFFFP_2036387790_Curaerror.gcode
    This is also what I did when I went in and 'fixed' my installs (3.6 and then 4.0 beta 2)
    I was having issues with my Cura. I killed all setup files, all Cura files and folders and did a fresh install of 3.6. I only installed 4.0 beta recently. During 4.0 beta I told it to not uninstall anything.
    sorry for delay, I solved the problem by the following procedure
    1. saved my Cura profiles and materials
    2. removed  all Cura installations
    3. Reinstalled Cura 3,6
    4. Imported back my Profiles
    Now it seems everything is just fine
    That is good to hear. 🙂 I wondered if that was why it sliced well for me. Seems to be the answer. To me then, this points to an upgrade issue with Cura?
        • 6 replies
