@smartavionics:
Actually I tried to do this , but as soon as I try to save a project in CURA
the program seems to crash and terminate.
Afterwards I find a .3mf file in the directory, however it is empty.
This happens with CURA 3.6.0 and CURA 4.0.0
BTW: Everytime after slicing when I write the gcode-file to my SD-Card, CURA crashes/terminates as well;
but in this case I find a valid gcode file on the SD-Card
burtoogle 506
Hello @claus1812, to understand what is happening there, it helps a lot if you could save the project file (File -> Save) and then attach the .3mf file to this issue. Thanks.
