Hi, thanks for the reply,
In "Settings/Printer/Manage Printers../Machine Settings" the "Nozzle size" is already set to 0.4mm (the good size for my nozzle).
I have a good .gcode made in Cura, I'll try to load it settings as a new profil, I'll tell you the result.
Edit :
So, I've replicated the good .gcode file with the good .stl in Cura to get a bad .gcode file.
Now, I've oppened both of the .gcode files in Notepad++ and I'm looking for differences.
So far I've fixed a dozen of settings, I think the main cause was the flavor, it was set on "Marlin (Volumetric)" instead of "Marlin"
I'll keep you informed.
Edit #2 :
Problem solved, there is still a difference in the .gcode files line 33 ("G0 F3600 X85.065 Y85.582 Z0.1" for the good gcode and "G0 F3600 X85.072 Y85.575 Z0.1" I didn't found where to change the X and Y coordinates but I don't think it's a real problem.
Here is the things I changed for record :
PRINTER SETTINGS G-code flavor "Marlin (Volumetric)" > "Marlin" MATERIAL Printing Temperature 200 > 195 Build Plate Temperature 60 >65 SPEED Print Speed 50 > 40 Travel Speed 50 > 40 Initial Layer Speed 20 > 60 COOLING Enable Print Cooling OFF > ON Fan Speed 0 > 100 Initial Fan Speed 0 > 100 Regular Fan Speed at Height 0.5 > 0.1Edited by Mr_Pioupiou
Labern 772
Maybe the material diameter is set to 2.85mm. I have seen that some people have had issues with cura defaulting to 2.85mm.
