kmanstudios 1,088
I have not. I use a PVA slurry that can be dissolved. If frozen, will cut loose.
I have chipped glass with PLA.
So, I am thinking it should not be the glass.
Hi Kman
Being a service provider, PVA is a PITA to manage (application, removal) so I use sprays mostly.
Printing ABS with PVA doesn't make the trick, generally I go with Dimafix, but for that specific grade 3D Lac is sufficient.
I use glass plates from my local supplier on a Mankati Full-scale XT Plus, 4mm heat tempered glass made to measures, without chipping issues so far.
What's why I'm wondering if there isn't an issue with the genuine Ultimaker S5 glass plate....
BTW it would have been good to have the aluminium build plate.
Edited by V3DPrinting
1 hour ago, V3DPrinting said:Printing ABS with PVA doesn't make the trick
This I get. But I did not make clear that point or that it was just a thought of having something that would provide for a barrier. :)
Sorry I clarify my point.
Printing ABS with PVA doesn't work well for warping, not consistent compared to Dimafix spray.
3 hours ago, V3DPrinting said:Hi Kman
I mean not to throw a random punch; and yet.
Your issue is a great example of what the aluminum build plate was solicited to eliminate.
Takes care
I'm having this exact same issue on my S5, though I am printing polycarbonate. Lots and lots of polycarbonate.
I never use tools to remove parts from the build plate, I just wait until the part cools and it detaches itself. The shear force of cooling must be hard on the borosilicate.
The part below was a 13-hour job consuming most of the build plate, so the bed was at high temperature for a long time. I use school glue for adhesion (since this is polycarb) and in general the part's pretty well stuck onto the plate until the bed cools.
I need to stock up on build plates I suppose!
(by the way, weren't we supposed to get aluminum plates a long time ago?)
You can see the divot below and also the piece of glass embedded in the printed part, which is kind of cool when you think of it.
/Mitch.
38 minutes ago, MitchL said:I need to stock up on build plates I suppose!
Yes aluminium plate would have been great ! But the project was cancelled at Ultimaker, so we would get an extra glass plate.
I am thinking of having some glass plates done by my local supplier for my S5.
It's not cheaper, but I suspect quality is better as far as I can see on my Mankati.
I have the same issue when printing PC. So I do understand why Ultimaker cancelled the aluminium plate, they make a lot more money of us with all the glass plates we have to replace. 😉
It is an old thread, but it happens to me too.
Printed UM ABS with 3DLac and chipped on side of the glass. Today I printed again UM ABS with Magigoo instead of 3DLac and now chipped the other side.
So next time I will print with the adhesion sheets to protect my glass.
Also be careful with CPE+, if you don't apply enough glue it chips very easily. It seems like things that need a high plate temp make it more susceptible. (CPE+ and polycarb default is 107C!)
I have managed to print FormFutura TitanX (ABS) on my S5 without any glass chipping, consistently using Dimafix.
If you spray a thick layer of Dimafix on the glass plate, it will protect it and while hot provide the right amount of adhesion.
It also works fine with PC and CPE+
For CPE, I still use 3D Lac, but the bed leveling has improved in the last FW version and I nearly don't have anymore first layer too squished on the build plate. Which is the cause of the chipping with CPE.
A few years ago there have been discussions among people using ceramic plates or tiles instead of glass? I don't know if that has been developed further, and if it could be a solution?
V3DPrinting 5
In addition, finishing the print run, I had another time the same chipping issue.
Hopefully it was on the same glassplate. So now it is really dead on both sides.
Has someone had the same issues with the S5 glass plates ?
