Thanks for your help mastory. So if I'm understanding you correctly, the first layer is printed with the nozzle at Z=0 (which is actually about a paper's thickness above the bed) ?
And while I've got you on the line: Is it normal for the first layer to form a narrow brim around the object or would that be considered an "elephants foot"?
Edited by Reywas
mastory 42
I can see where this could be confusing at first.
The zero position for Z is with the nozzle above the build surface by some distance, often a thickness of paper. The Initial layer height is referring to the actual thickness that the printer is trying to print in the first layer - not the Z position. A good practice for strong adhesion to the build surface is to print a little more material than the actual gap from the nozzle to the bed. In your numbers above, your printer should extrude enough material in the first layer to a achieve a .3mm layer, however there is only .25mm of space. This will result in the material being slightly smashed into the printer bed promoting good adhesion.
On materials that resist sticking to the build plate, it can be helpful to over extrude even more than in your example numbers. On lots of printers, you can manually adjust the Z position at early moments of the first layer to get the distance just right. Not sure about your printer, but I don't hesitate to give the Z screw a twist (by hand, over-driving the stepper by a few poles) at the very beginning of a print to get the distance just right.
Edited by mastoryLink to post
