  • 2 years later...
Posted · What is Cura's Error Message No. 13?
Cura does not know what it means. It is just what the OS says to Cura, when Cura attempts to write the file.  If I would know what OS you use, I would Google what error 13 means for that OS.
Without knowing your OS (and Google), I can only guess. A somewhat safe guess is that the OS is telling Cura that there are insufficient user privileges to write (or overwrite) a file, or that you are trying to write to a read-only location (eg an SD-card which has its write-protection switch turned on).
          • Heart
        • 7 replies
