Thanks for the info Torgeir. Its very odd they dont colour code the wiring anymore. 2 grey and 2 black wires in the new cable...doesnt make it easy to fit.
Hi vwguy16,
Just some more info; the two black wires is power for the heater, the two gray wires is going to the PT100 temperature sensor.
Both, the heater and the temp sensor is not polarity sensitive, as they are floating from ground.
When looking into the printer, the two connecting points to the left is for the heat bed and the two to the right is for the PT100 temperature sensor.
Good luck
Torgeir-
2
Thanks for your help Torgeir, the UM2+X is now back up and running!!
Glad to hear that your printer is up and working.
Happy printing..
Cheers
Torgeir.
Torgeir 289
Hi vwguy16,
Welcome in here.
As far as I'll know, the heated build plate used in UM2+ is the same as used in the UM2 and you find it here:
https://3dgbire.com/collections/spare-parts/products/ultimaker-heated-bed
The brownish color around the stepper driver IC's is kind of normal for this printer.
You can reduce the heath build up by using an external fan directed toward the vent opening.
I've installed two small fan outside the metal shield covering blowing into the main circuit board -and my PCB have no sign of overheat, still looks as brand new..
Also worth to know is that the little PT100 sensor on the heat bed somtimes fail, and can be changed.
Thanks
Torgeir.
