I can't really explain everything, but these look like extrusion issues. What you can try:
* Clean the heads using hot and cold pull method
* Check the temperatures at which you are printing. Maybe increase them a bit?
* If printing PVA is making popping/hissing noises, it's probably because the PVA has absorbed too much moisture. Try to dry it on the build plate, or with another technique.
Keep in mind: PVA is a very difficult material. You have to keep it in a bag as much as possible and not expose it to air for too long. On my UM3 I have the same problem as your 2nd print: when there's not much support to print and there's a lot of retraction, it will just clog up the nozzle. The only workaround I have found is to try to increase the amount of support material that is printed. For instance, enable a prime tower.
What is the other (green) material? I haven't had any issues with PLA at all. It's just PVA that is giving me headaches.
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
pbackx 11
