Sorry @phantom, those are not project files, they only contain the model and not the settings. Please do File->Save (not export!) This catches a lot of people out and I have requested that the menu gets altered to make it more obvious but the Cura developers didn't want to do that.
Hi @phantom, the answer to this little mystery is that setting the slicing tolerance to exclusive had the effect of changing the bottom layer. Setting the slicing tolerance to middle shows the missing layer which is indeed shrunk as you can see from the image.
This looks like a bug to me because I would have thought that the first layer horizontal expansion should not be influenced by the slicing tolerance.
Edited by burtoogle
FYI, I submitted a PR (https://github.com/Ultimaker/CuraEngine/pull/1014) to fix this, don't expect to see it in Cura anytime soon.
1
- 1 year later...
On 3/14/2019 at 1:17 PM, burtoogle said:Hello @phantom, in those two files, the settings at the end of each of those files do not contain a value for xy_offset_layer_0 which is what the Initial Layer Horizontal Expansion setting is called internally. So, for some reason, you are not setting that to a non-zero value. Can you please attach the project file (.3mf). Thanks.
burtoogle, I have the same problem, initial layer is expanding, but I have set the expansion to -0.25 and the xy_offset settings in my gcode files say -.25.
I tried setting my initial layer really thick, thinking I was too low and squishing out the PLA, but it still expands the first layer. I can see it in the preview so it isn't a hardware problem, Cura is telling the machine to do it. Any other idea's on how to stop this expansion?
Don
Edited by bmwbykrydrGregValiant 1,141
Well that was interesting. There were so many models scattered around in the 3mf file that for a minute I thought I was looking at my garage floor.
"The model is not watertight". I used the Cura mesh tools and it seemed to fix it. Mostly though, it was buried in the build plate.
You had Horizontal Expansion set to -.25 for the whole model and Initial Layer Horizontal Expansion set to -.25. I don't know for sure but the net difference was probably 0 so it wasn't setting the first layer inboard.
Here is how it came into 4.8. The model kinda looks like your screen shot.
This is after repairing the model and moving it up to Z=0. The first layer is a really small patch and looks nothing like your screen shot. Are we talking apples and oranges here? Or...it's a Honda part and you're trying to fool me.
After making some adjustments to the quality settings I set Initial Layer Horizontal Exp to -1 and it looked like that worked. Back to -.25 and that worked as well. (That was with the model back to be half buried in the build plate just in case.)
Edited by GregValiant
That was it! Thank you. And now seeing it, that makes perfect sense. I am not familiar with the mesh tools so I'll dive into those today.
And, for the record, I moved the model down like that to print two halves and glue them together. (I got lazy and didn't want to export another STL of half the model).
That is what my garage floor looks like. You got a problem with that?! 🙂 (My wife does...)
burtoogle 510
