1 hour ago, fbrc8-erin said:The sliding blocks absolutely need to be straight up and down in the printhead shafts. Loosen the printhead shaft from both ends of the sliding block at the same time, get the first one perpendicular, and then you can manage the second one.
Yeah, thats what i assumed at first.
It (the sliderbloack) came from print maintenance people slightly squint, and i only noticed afew days in, i also then noticed the print head slant. It was printing fine at this point.
I looked up online how to straighten the slider blocks and did so, and immediately noticed it made the print head slant MUCH worse. At this point, it wouldnt print at all. I put it back to being slanted (which raises the print head shaft to be slightly more level) and it now prints a a lot better but still fails quite often, ive been tinkering with it for literally 10 hours now and cant get it to print properly on almost any print head (was printing fine on 0.25mm before).
Im not sure if its clear from the photos but you can see the slant is worse when the sliderblock is straight.
fbrc8-erin 266
