STL files don't store the units. Even if you designed it in mm in 123D, you may be exporting it in inches or meters or feet. For example if it's in meters and because cura expects mm it will be 1000X too small.
So when you export from 123D I think there should be somewhere an option to select the units. Select mm.
gr5 2,333
fmanchu 0
Many thanks for your quick response. Although your answer did not help directly, it put me onto the solution.
Whilst looking for the option to 'select mm' (not available) I came across the option to 'Combine objects'.(please see attached)
Happily this solved the problem immediately and Cura accepted my model.
