Spool NFC tag repported as corrupted
Matioupi
Posted · Spool NFC tag repported as corrupted
Hello,
the tag of the PVA spool delivered with my UM3 is not recognized by the unit. Other spools works ok on either slot 1 or slot 2 so it seems to be spool related.
When going to maintenance menu and testing the NFC reader, this spool is reported as :
CORRUPT_STAT
Not sure if this is related, but behaviour appeared after upgrade to 5.2.8 firmware on my 1 month old UM3.
