I do not see the left hand side menu. That is what I need. Can you help.
The buttons are showing but are not lit up and so cannot be activated.
I have it now thank you for your help!!!
You have to select (click) on your model first, but I guess you already found it 🙂
Smithy 1,141
The orientation depends on the orientation when the files was exported as STL. So if it is not laying flat it was also not in the right direction in the CAD software.
But it doesn't matter, you can freely rotate your object in Cura as you like and also push the button by the rotate tool in the left menu, to put the model flat on the bed.
