Posted · Pause at height script Buzzer, cura 4
Hi all, relative newbie here.
Is there any way I can edit the pause at height script to include a custom action ie. sound the buzzer for user attention.
(I have already added a buzzer script for print finished, at end of Gcode, in  the printer setup, but can not find where to add it for user intervention in the scripts).
Thanks
Bob
    • 3 weeks later...
    Thanks
    Bob
    OK - NO comments / replies. :))
    After a bit of scratching around I found where the Pause_at_height plugin was. Copied it and added a line to the Python script to write the Buzzer instruction to the Gcode output. Found the folder for user plugins / scripts and saved it renamed as Buzzer_Pause_at_height.
    Quite why this was not implemented in Cura4 by default I have no idea. It is pretty easy to add the option to buzz, (or not), to alert the operator with a true / false input. And is much easier than having to be waiting at the printer for it to stop.
    • 2 years later...
    Hey @Bob19,
    Good news - I was also looking for this. I just spotted that you can now add 'G-code After Pause' in Cura under the 'Pause at Height' plugin (I'm using 4.11.0 OS X). The example they now give is adding a m300 code for beeping.
