Posted (edited) · Solid Shell within Infill? Cura 4.0
I have a prototype for a client that keeps failing.
On an angled cylinder extruding 80 degrees from a flat plane, the joint between its shell and infill at the base has very weak fusion. This is happening with Matterhackers Build series PLA at a .2 Layer height and a grid infill of 20%.
So in my efforts to remedy this problem, I am wondering if there is a way to print the base of the cylinder that's vanished through the slicing process and been turned into the void space that is infill, as a shell within the infill. I aim to increase the stability of this part of the print by basically trying to set it inside like a post in the ground.
Is this possible in Cura? Or is it something I have to do in the export of my model from my CAD software?
Any suggestions for this or more obvious solutions to this problem would be most appreciated!
Edited by 3DSmokeware
