2 hours ago, gr5 said:when you say "crashes" do you mean two things are colliding?
Do you mean the computer crashes?
The power brick is operating always just a bit over it's rated power on the UM2 and often it gets upset and the computer in the power brick cuts power for a few tenths of a second which causes the firmware to reboot. Could that be it? Does it end up at a working home screen?
There are some cases where tinker firmware crashes randomly and hangs up. I have workarounds if this is the issue.
Please supply more information. Maybe send me a DM if I don't respond within 10 hours as I often "lose sight" of threads.
Hey!
So when I say crashes, it locks up the menu still shows that it's printing but the head isn't moving and neither is the bed. But the screen is locked up so you can't abort etc. You have to turn off and back on again.
The fw is up to date, and u have tried three different power packs to see if another one makes a difference and still no luck.
gr5 2,330
