Thanks for the reply.
I have an Ultimker 3. Sorry, I forgot to mention in my original post.
Is there also a solution out for UM3?
no, sorry. The UM2 is more hackable. You have to edit the gcode. Basically remove the layers that printed already from the gcode and you have to add a G92 for extruder position (which is broken in 5.2 firmware). Read about G92 here:
https://reprap.org/wiki/G-code#G92:_Set_Position
Basically look at the last E value that you delete and set the position to that value. So if the last deleted printing move was:
G1 X123.432 Y23.4433 E1000.5123
Then replace it with
G92 E1000.5123
Other wise it will try to extrude a meter on the first printing move.
OK. I will try when teh problem occurs next time.
Thank you for your help !!!
gr5 1,971
Yes you can! If you have a UM2 series printer. Get this firmware which is really great. Really great. And lets you say which layer to resume on:
https://github.com/TinkerGnome/Ultimaker2Marlin/releases
