Thanks for these suggestions. I have been trying different speeds and slowing it down seems to improve the surface but I'm still getting spiral ridges. I'll try different layer heights.
- 2 years later...
Hello, Was this problem ever solved? I am new to 3d printer and seeing the same problem, the sample file works great all other files ran through cura create mesh walls.
Please show a photo. Not all thin wall issues are the same.
gr5 2,333
Most likely you printed too fast (too much volume per second). Try printing at 1/3 layer height or 1/3 the print speed to see if that helps. You can even mess with the speed while it's printing (you don't have to reslice) so you can experiment and do a few layers at various speeds and keep notes.
