Feeder Stepper Motor Modification for Extrusion Issue
Posted
· Feeder Stepper Motor Modification for Extrusion Issue
What's the printing temperature?
There's a firmware feature called "cold extrusion prevention" with a minimum temperature of 170°C per default, but it can be changed with a gcode command, see:
Posted
Thanks for the quick response! We're trying to print at about 134 C maximum, and will need to print at lower temperatures. I believe it may actually be this cold extrusion prevention. I had seen it on a forum elsewhere, but was unable to find how to fix it. Thanks! I'll post about if I'm able to get it to work!
tinkergnome 926
or...:
https://reprap.org/wiki/G-code#M302:_Allow_cold_extrudes
dantheteaguy 0
