Problem with filament on Ultimaker 3 extended
Posted · Problem with filament on Ultimaker 3 extended
Hello!
I know this has been covered before but I can not get it to work with the previous suggestions so I thought I should make my own post.
I have problem with the feeder and the filament not going through.
I have cleaned the feeder, the head and the tube. I have tried with different tension on the feeder wheel, could it be a temperature issue? (as I said now I am printing with standard settings).
I use CURA 4.0.
I tried to print a test cube with standard settings and ultimaker PLA material.
It starts off fine but then it just gets weird. Anybody have any ideas on what the problem can be and how I can solve it?
Thank you for your help!
