Preview simulation bar not visible
Andrea22
Posted · Preview simulation bar not visible
On 12/29/2019 at 8:36 PM, CoolHandMike said:
Hi r4ph,
Thanks for the suggestion. I tried to enable the Radeon driver to launch Cura as you have advised, but there is still no simulation preview. I will try again on my laptop (which has a Nvidia GTX 1060) and report back.
Don't forget to turn off compatibility mode and restart the  cura afterany changes.
    • 2 years later...
    Posted (edited) · Preview simulation bar not visible
    Hello. I have a similar problem. When I press the play button to see the building animation, I can see just a few seconds. The building animation is a few seconds short, and its building only the end of my Yoda. I tried ot search on internet, but i couldn't t find anything useful. I just started 3D. Thanks.
    EDIT:! I got it now. I found out by myself. Isn t a problem. Its the animation of the active layer. I was on layer 47, thats why the animation was so short.
    Edited by Iosua101
    That's normal.  It's playing the layer you have selected on the right.  In the same video you posted there is a vertical scroll bar.  You can use your mouse to grab the top ball and drag it downwards to see other layers.  You can also drag the bottom ball but I recommend sticking to the top ball.  Once you've clicked the top ball you can also use ctrl+up arrow and down arrow to scroll through the layers.
    The play button only plays one layer - the current layer selected.
        • 13 replies
