7 minutes ago, Smithy said:First of all, I would cross-check it, with another filament, if it is ok with a "normal" filament, then you can be sure that your self-made filament is the root cause. A consistent diameter is very important to avoid over and under extrusion.
The printing quality with normal fimalent is just fine, I tried the same tower with ABS.
I just don't understand why the first lines are pretty good quality with the self-made filament when the inconsistent diameter is problem for the bad quality.
Edited by 3D-TH
Smithy 1,132
