If you look at the footprint of the object, it does not come close to the clamps, so that's not the problem.
Edited by JimTIt is the problem, because Cura don't just check the footprint, you see it on the shadow, it uses the whole object to check if it fits or not. Makes no sense, but it is so.
4 hours ago, Smithy said:It is the problem, because Cura don't just check the footprint, you see it on the shadow, it uses the whole object to check if it fits or not. Makes no sense, but it is so.
If that's the case, then it is a bug in Cura, which should be fixed.
Smithy 1,111
I think the problem are the clamps on the glass. I loaded your object and reduced it just about 1mm and it fits. So yes you have 120 x 120, but not at the same time 🙂
