Hi @geert_2 thanks for the great tips. I'll might have a look at DesignSpark but I'm using FreeCAD because it FOSS software/GNU, has many workbenches, and can be scripted with Python. Yes, it's been quite unstable, but I haven't had v0.18 crash on me yet.
I can hear from what you're saying that it's not so easy to click things together. I think I might be better going with a regular screw recessed into the bottom of the base and going into a nearly big enough hole in the bottom of the top section. I'll let you know how it goes (very slow spare time project).
geert_2 462
If you are on Windows, I would suggest you try DesignSpark Mechanical for editing: this is also free (just requires registration) and is much easier and more stable than FreeCAD. There are a lot of good tutorials on Youtube. Have a look at them and see if you like its concept. Or try any of the free online-programs (I have no experience with them).
Then for mounting, in my experience:
For multiple-part objects, I often mount them with nylon screws and nuts. Provide the holes and hex-indents for the nut and screw in the model, so they sit recessed and are easy to assemble and disassemble.
Press-fitting parts requires a lot of testing to get it right, and PLA (and lots of other 3D-printing materials) tend to creep under mechanical loads, so they deform over time. So the fitting may become loose.
Snap-lockings work well for PET. For PLA they work when inserting, but after a year the PLA gets harder, and then the snap-locks break apart when you try to unlock them.
3D-printing screws and threads is hard, and tapping them is even harder, especially in PLA: this melts almost immediately.
Glueing with cyanoacrylate works pretty well for PLA. Depending on the circumstances, this can be a good option.
One of many possibilities of a clamping bolt and nut (this one has to slide and be adjustable):
