Many tks for your answser with your helpfull feedback. Congratulations for yours prints..... We also have to face with the macro pictures distorsions.
We are printing with an 0.15mm nozzel with a layer heigth of 0.08mm. This work well too :
To fix the ideas for the duckboard : the rectangular holes are 0.36mm x 0.36mm and the solid part between two holes to a width of 0.274mm. His thickness is 0.374mm. The filament used is a PLA PREMIUM from 3DONLINE.
our discussion between us was about the CURA process :
Any idea how does CURA react on the flow if we reduce the line width by 10% as per their recommandations ?
some said that the flow is automatically reduced by 10%, others said that Cura do not impact on the flow when changing this line width setting ?
Many tks
Philippe
gr5 1,968
I've printed with 0.15mm nozzle before with good luck.
I used 0.15mm for the line width and that worked fine.
I was printing very small things and the part wasn't cooling enough (the nozzle touching the part was keeping it hot so it never got solid and was a big gloopy mess). The solution was to print 7 items (or at least 3!). This way each item had time to cool while it printed the layer on the next part over.
Some people recommend a cooler nozzle temperature also but that didn't help me much.
I printed 0.1mm layer height such that the Z resolution matched closely the XY resolution. That worked quite well.
Please post pictures and include part of your finger for scale. I find coins for scale don't help me much unless I happen to have the coin with me. I always have my finger with me so I find that to be better for scale.
gr5 1,968
These were made with a 0.15mm nozzle. The quality looks crappy until you realize how small they are. The imperfections seen easily here are not so easy to see without a magnifying glass in real life. That's not my thumb - that's a finger.
I like that you can tell that the closest figure is a man holding a young girl - you can easily see where her knee bends.
"retraction minimum travel" defaults to 0.8mm but I should have changed that to 0.1mm for this print to get rid of all that stringing between the other man's legs.
Really these do not look impressive in this photo but look very impressive in real life.
