Thanks gr5!
Indeed it is the same issue. I connected a scope on the stepper and it really explains it all.
Clearly the stepper driver is loosing the current driving sync when changing between the drive modes, exactly as the data sheets explains.
I will change the resistors and hopefully it's all sorted.
Big cheers!
gr5 2,070
F50 is 50mm per *minute*. Not second. So that's very slow. That's slower than 1mm per second.
Yes that vibration/noise is EXACTLY the same issue as with zebra stripes. There are two great solutions.
One is to short circuit a jumper on the UM2 board. There is discussion of this on this forum.
The other solution is to buy a TL-Smoother.
Read torgeir's posts and any posts mentioning tl-smoother or triangle labs.
