If the 2 models are also correctly on top of each other in CAD and are saved as separate STLs you can use the merge function in CURA (select all, right mouse click on the model) to position them correctly.
Hey, thanks for the reply. I've unchecked this and the model itself shows that it's moved/floating in Cura, but when I actually slice it the gcode that it makes sets the z-position back to 0.
For reference, the image shows the silhouette of the model's actual positioning, but the produced gcode remains at z = 0.
Edited by Luscious_Bagel- 2 years later...
On 5/26/2019 at 2:02 PM, Luscious_Bagel said:Hey, thanks for the reply. I've unchecked this and the model itself shows that it's moved/floating in Cura, but when I actually slice it the gcode that it makes sets the z-position back to 0.
Did you ever figure out the solution to this problem? I have the same problem.
Thanks
uncheck the parameter "Remove Empty First Layers" in the Correction section
- 5 months later...
Thanks for this discussions. This works.
gr5 1,872
go to the menu system in cura: "preferences" "configure cura..."
Uncheck the box that says "automatically drop models to the build plate".
Instead of moving the model by the blue arrow up and down I recommend you enter a Z value (you can do either of course).
