Replacing the PTFE coupler on a UM2GO
JimT
Posted (edited) · Replacing the PTFE coupler on a UM2GO
I've just replaced the PTFE coupler on my Ultimaker 2 Go. I wasn't able to find instructions on how to do this for the Go, so I used the instructions for the UM2+ on this page:
https://ultimaker.com/en/resources/50672-replace-the-tfm-coupler
The print head on the Go is similar, but not exactly the same as the UM2+. Step 6 for the UM2+ says
  • To tighten the front two thumb screws, use the calibration spacer. Place the tool in between the aluminum plates of the hot end.
  • Tighten the front two thumb screws until the tool fits securely between the plates, but can still easily be removed.
I did not get a calibration spacer with my Go. Does the Go use the same calibration spacer as the UM2+? Where can I get one? Can I print one?
Thanks!
Edited by JimT
    Posted · Replacing the PTFE coupler on a UM2GO
    Wasn't that print head the same as the UM2 (non-plus!)? Or have there been different UM2Go versions?
    In the first case (=like UM2 non-plus), I think you don't need any spacers, because this was with a spring instead of fixed-length metal piece.
    Thank you! My UM2Go has the spring too. Are the instructions for replacing the coupler on a UM2Go  somewhere on the Ultimaker website? I couldn't find them. The UM2Go User Manual says that the instructions are on the website, but it doesn't have a link.
    Edited by JimT
    I don't know any link, but you can look for disassembling instructions, it is basically the same. And you can also look for UM2 which has the same print head as the UM2Go.
    I just found this link, which describes how to install the Olsson block, but the disassembling instructions should help you.
    "Ultimaker North America Support" (or fbrc8.com) is always a good source for such things:
    https://ultimakernasupport.zendesk.com/hc/en-us/articles/115004324223-Printhead-Parts-Ultimaker-2-#PTFE Coupler
    21 hours ago, tinkergnome said:
    Thanks. It's good to know that the North America Support website has information on the UM2(non+) that also applies to the Go.
        • 9 replies
