TinkerMark2 Z-offset menu?
Perchik
Posted · TinkerMark2 Z-offset menu?
In the TInker firmware, I remember a menu setting that let me tweak the z-offset after buildplate adjustment to fine tune it. For the Mark2 variant, I've seen the z-offset adjustment for the second nozzle, but I can't find it for the first nozzle. Was this setting dropped in the mark 2 variant? Anyone know where that setting is controlled in the source code? I've been compiling my own firmware anyway, so I'm fine to just flip a bit somewhere, but I'm not sure what that setting is called.
    Ah found the answer. In the Dual Extrusion menu, if you select extruder 1, z offset is for nozzle 1. If you select extruder 2, z offset is for nozzle 2.
