johnse has great advice.
But you shouldn't need a raft. Raft is an old technology and there are several newer generations of materials and printers since then. What kind of printer do you have? What material are you printing? You don't need raft with PLA. Ever. If you are printing ABS (don't print ABS) and you have a reprap style printer - like the prusa i3, then raft might be a good option. But if you have a printer with a heated bed you don't need raft. I talk about raft and the newer technologies - why they are needed - the purposes - and solutions - here:
1
johnse 30
You could use the technique often used for temperature towers. Select the menu Extensions->Post Processing->Modify G-Code.
Press the "Add a script" button and select ChangeAtZ. In there you can select a height (either mm or layer number) and select something to modify.
You can add the script multiple times.
