material not detecting for material 1
Posted · material not detecting for material 1
printer: ultimaker 3
Material: Gray ABS
Problem:Having problem detecting the material and have to physically enter the ABS generic instead for Gray ABS since the option does not exists. what do i need to do to change this option in the printer.
    Don't worry - Gray ABS and generic ABS use the same profile with the same temperatures and other settings.  Neither Cura, nor the printer need to know the color of the material.
    In real life, white pla and white abs do behave a little different but Ultimaker hasn't come up with profiles that change depending on color.  Yet.  I don't expect them to.  At least not for PLA and ABS.  By the way, ABS is not a great material - what are your needs that PLA wasn't good enough?  Temperature?  If you need a higher temp material consider CPE/PET or whatever people are calling it now.  PET is easier to print the ABS.  ABS is probably going to come out uglier and weaker without a lot of experimenting to get it right.  PLA is so much easier.
