Interesting, thanks for responding.
this seems to in contrast however to the very aggressive acceleration and jerk settings for travel, these are crazy high and really hammer the machine. If indeed the reason the max travel speed is 150 due to the print head weight the default jerk and acceleration settings should be adjusted (as they are more affected by a heavier print head, the max speed is only met after acceleration). I knocked mine back to way more sensible levels as the printer would actually shake !
Really Interested to hear from UM on this
Dim3nsioneer 557
Until you get the official answer, I can tell you that 150mm/s is indeed the correct travel speed for the S5. The reason for the lower value (compared to e.g. an Ultimaker 3) is the heavier print head. As the product aims at professional customers, Ultimaker has decided to give safe values the priority over speed.
