Sure - attached is one version
Hi @comyz, that's a puzzle to be sure. My only thought is that you are over-retracting and the nozzle is sucking in air which gets expelled later. Are you using 6.5mm of retraction at 25 mm/s in Slic3r also?
Possibly not, I think it may be defaulting at 1.5mm. What do you recommend and I'll re run it?
Depends on whether it's a bowden extruder or not. If it is, try 4.5. If it's a direct extruder then 1.5 could be right.
You were correct, changing the retraction to 1.5 solved the issue. Thank you!
burtoogle 509
Hello @comyz, could you please attach the gcode file so I can take a look. Thanks.
