problem transferring to sd card
Chico
Posted · problem transferring to sd card
Having trouble transferring prints to removable disc. Somehow the transfer shows on disc but no bites.
Or I get error re: G-code . Machine is a Qidi tech X-one 2. Been trying for weeks to resolve. Any help would be much appreciated.
Thanks.
    Could be anything, but try to save the Gcode to your local disk and then copy it to the SD card. If it is still not working, try to reformat the sd card. You could also try to clean the card reader on your printer.
