14 minutes ago, gr5 said:No culprits? You need to be a little more specific. Maybe circle something? Arrow something?
Ha...sorry. Thought it was obvious. The issue I am referring to is the curving that happened at the top of the print. I definitely know it wasn't the most ideal orientation...my later print came out fine. I was mostly curious if I could print it on the S5.
You may have nailed it with the wobble theory.
gr5 2,094
It was probably wobbling around while you were printing. I would consider putting a little bit of support - added in CAD - to keep it from being to wobbly.
But I don't understand the question.
Um...
