1 minute ago, tinkergnome said:you have to add appropriate header (comment) lines at the beginning of the file. Simplify3D - for example - does it with a post processing script.
Thanks!
Unfortunately, I will not be the one to create the files for print, or neither will i be able to control them. thats why i am trying to go around and try the x-Fields.
tinkergnome 918
regarding x-Fields: i have no idea, i guess it's undocumented for a reason...
Anyway: the printer reads the mentioned (meta-) data from the gcode header only (AFAIK).
That means: if you want to send gcode files from other sources, you have to add appropriate header (comment) lines at the beginning of the file. Simplify3D - for example - does it with a post processing script.
