4 hours ago, LoS said:Hi! This happens on my S3 when using 2 3d Solex Hardcore (AA + BB). When using 3d Solex AA + Ultimaker BB everything is alright.
I had the same issue with 3d Solex Hardcore on my S5. It was linked with the spring being too weak and the seating of the print core in the printhead.
Checking the spring length and extending it a bit has solved the problem for me
gr5 1,858
So maybe try like they said and do a "factory reset". It's in the maintenance menu. Then the next time you level it should be okay.
Personally my UM3 (pretty much the same firmware) remembers the leveling for pairs of cores but when I switch to an older set I always have to relevel (but I do only manual leveling on my UM3). So something is off about how it stores the previous leveling values (I'm careful not to touch any of the 3 screws when I level since the bed is perfectly level - it's just the height from nozzle to glass that I'm trying to calibrate).
I have a few 3dsolex core's myself and I do customer support for people with them if they are in the USA so I'm very interested in this topic. If you are in USA we can take this offline if you want.
