ok, I have checked all and found that there are no values for support infill steps. what should the values be? and should I set values for everything in the support option? thingiverse didn't have instructions for that. also I am not seeing the supports in the viewer. thank you
obewan 24
On the top left, click settings/configure setting visibility, then tick the 'check all' box.
now under 'support' check the value you have set for gradual support infill steps.
