Posted
· Is it possible to get a whole first layer
The bottom of your model isn't all at the same level. You have a few options. Usually when this happens to me I go with the simplest option. I go to menu item "preferences" "configure cura" then uncheck "automatically drop models to the build plate" then click on the model in cura so it is selected and on the left side of the screen select the icon to "move" the part then set the z value to a negative value. This will chop off a bit of the bottom of the part. You might only have to chop off 0.1mm. (set Z to -0.1) but typically I have to cut off at least 1mm. Depending on the model.
I suspect the reason the results are different in S3D is probably that your bottom layer height in cura is 0.27mm and 0.3mm in S3D. If this is true then you can go with method 2 which is to increase bottom layer height until it includes enough of the model
A third option is to fix the model so that everything that you want to start on the first layer... starts on the first layer.
How to Enter
Design an Ornament
Entering a new design
Entering an existing design
Winning designs should:
Be original Creations
Share the creative journey! Include documentation of your design process, giving us a peek behind the scenes. For example, show a screenshot of the model in your design program. Use the Tag Holidays2023.
Make sure your submission aligns with our guidelines and Thingiverse's Terms of Service.
Good luck 🎉
A year after the merger of Ultimaker and MakerBotQQ, we have unlocked the ability for users of our Method series printers to slice files using UltiMaker Cura. As of this release, users can find profiles for our Method and Method XL printers, as well as material profiles for ABS-R, ABS-CF, and RapidRinse. Meaning it’s now possible to use either Cura or the existing cloud-slicing software CloudPrint when printing with these printers or materials
gr5 2,097
